Activity Forums AJA Video Systems Kona LH and Sony F550
  • Kona LH and Sony F550
    Posted by Johnnyp on December 19, 2005 at 5:22 pm
    HELP!!!! Is there any one out there that tell me how to properly connect the KONA LH card to the back of the F500 deck? Or direct me to a tutorial site?
    Jp
    Bob Zelin replied 20 years, 8 months ago 2 Members · 1 Reply
  • Bob Zelin
    December 22, 2005 at 1:40 am
    HDW-F500 HD-SDI out to Kona LH HD-SDI IN. If you know how to use the menus’ in Final Cut Pro (like Easy setup, and you have loaded your Kona drivers), select Kona 2 8 bit uncompressed HD, or 10 bit, or even DVCProHD, and it will work.
    You can also confirm this working by opening up the Kona Control Panel (which you download from the AJA website), and it will show you the output.
    There are only 2 cables you need to connect- the one video cable, that handles the embedded audio as well, and the RS422 VTR control cable.
    Thats it (unless you are genlocking to a black gen, in whcih case you need 2 more cables).
    Bob Zelin
