Activity Forums Panasonic Cameras KOna IO HD SDI from AJ-HD150 or 1200A by firewire–which?
  • KOna IO HD SDI from AJ-HD150 or 1200A by firewire–which?
    Posted by Phillip Powell on January 28, 2008 at 9:32 pm
    HD VeriCam shoot 720p 23.98.
    Can capture from either AJ-HD150 HD SDI into KONA I/O or 1200A by fire wire.
    Is there going to be a noticeable/visible difference between the two? I’ve just
    got to do some frame grabs at best possible quality, and file size really isn’t an
    issue.
    p2
    Phillip Powell replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
