Activity Forums Panasonic Cameras Kona IO HD SDI from AJ-HD150 or 1200A by firewire–which?
  • Kona IO HD SDI from AJ-HD150 or 1200A by firewire–which?
    Posted by Phillip Powell on January 28, 2008 at 8:40 pm
    Can capture from either Panasonic 1200A by fire wire, or from AJ-HD150 from HD SDI thru
    Kona I/O. Usually do the 1200A route, but need to output best quality possible frame grabs,
    and wondering if there’s a noticeable/visible quality diff between the two.
    File size not an issue.
    Thanks.
    p2
    Phillip Powell replied 18 years, 7 months ago 2 Members · 2 Replies
  • Gary Adcock
    January 28, 2008 at 9:23 pm
    [pSquared] “need to output best quality possible frame grabs,
    and wondering if there’s a noticeable/visible quality diff between the two. “
    yes there is a sizable difference between a frame grab from a uncompressed capture and a firewire capture.
    the uncompressed will look and reproduce better.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Phillip Powell
    January 28, 2008 at 9:37 pm
    Sorry. I/O’s in the other room.
    Thanks gary.
    p2
