Activity › Forums › AJA Video Systems › Kona HD & SD at the same time.
  • Kona HD & SD at the same time.
    Posted by Scott Shucher on May 25, 2005 at 1:29 am
    I’m pretty sure you can do this, but I want to double check before I finish ordering the hardware.
    I plan on feeding my Sony PVM-20L5 Hi Def monitor via the HD analog component out of the Kona 2. I’m assuming I can also feed a Kona 2 downconverted signal to the SDI output (then to an AJA Component D to A) to feed a TEK 300A waveform monitor at the same time as the HD signal.
    Scott Shucher
    AppleCart Digital Video
    http://www.applecart.tv
    G5 2.5ghz DP, 2.5Gbyte RAM, FCP HD 4.5, OSX.3.7
    QT6.5.2, CW 4.7, Pro Analog BOB, Atto UL3D, Medea RTRX640, Huge MV 1.8Tbyte, Radeon 9800XT
    Bob Zelin replied 21 years, 4 months ago 2 Members · 1 Reply
  • Bob Zelin
    May 25, 2005 at 1:31 am
    the answer to your question is YES
    bob zelin
