Activity Forums AJA Video Systems Kona HD Le – Monitoring DVCPROHD Output
  • Kona HD Le – Monitoring DVCPROHD Output
    Posted by Mad Media on April 6, 2007 at 7:45 pm
    Hi there,
    Just got my Kona card and I’m trying to monitor my DVCPROHD 720p60 sequences.
    Having trouble doing so.
    Simple set-up.
    Going Component RGB out of the card into my JVC NTSC monitor. No SDI or HDSDI I’m affraid.
    I have the sequence, video out, and Kona control panel all set to DVCPROHD 720p60 – Though I notice on the FCP Video Output it says RGBA –
    Any clue what I am doing wrong?
    Is it the case that DVCPROHD 720p60 can only be monitored via SDI or HDSDI?
    -J
    <>MAD MEDIA DESIGN<>
    Jeremy Garchow replied 19 years, 5 months ago 2 Members · 6 Replies
  • Jeremy Garchow
    April 6, 2007 at 9:33 pm
    Within FCP, hit control-q and choose AJA KonaLHe 720p60 DVCPro HD Varicam.
  • Mad Media
    April 6, 2007 at 10:04 pm
    Hey Jeremy,
    Thanks, but I’m not seeing that option in my set-up menu.
    I see 23.98 and 59.94 – neither of which work though…
    Any thoughts?
    I did update the Kona drivers to the latest stuff when I installed the card.
    I don’t see anything in the A/V setting for DVCPROHD 60p either under Kona.
  • Jeremy Garchow
    April 6, 2007 at 10:22 pm
    59.94 is what you want. I think you need to down-covert or is your monitor an HD monitor?
    If HD: go to View > External Video > All frames
    If SD: this is how you down convert to SD using the Kona: https://forums.creativecow.net/readpost/8/929482?
    You will have to apply the analog output where I have said SDI in that post.
  • Mad Media
    April 6, 2007 at 10:44 pm
    Yeah it’s SD. Going component RGB analog out to the input of the monitor.
    SO I have everything set-up to 720p59.94, and the Kona control panel is set to this as well, with the secondary at 525i29.97. But I am getting two large vertical black lines and the image is a bit scrambled. Something is still not right.
    Editing timebase on my original timeline is 23.98. Should it be 59.94?Sorry – still a bit confused about the signal path.
    -J
  • Mad Media
    April 6, 2007 at 11:13 pm
    GOT IT! I had to select “secondary’ on the Kona Control Panel. DUH! Thanks for the help though Jeremy.
    -J
  • Jeremy Garchow
    April 6, 2007 at 11:33 pm
    Cool. Have fun and take chances.
    Jeremy
