Activity Forums AJA Video Systems KONA, FCP and audio monitoring issues?
  • KONA, FCP and audio monitoring issues?
    Posted by Jamie Nabers on December 13, 2006 at 12:42 am
    hey team,
    i just assembled my new edit suite today. My issue is, I cannot get the RCA audio monitoring outputs on the K box to output any audio. I can get audio from my timeline to my deck via the SDI connections, but wont come directly out of the K box. I am viewing component out of the k box to my monitor. is this an FCP issue or a kona problem?
    My set up:
    G5 quad 3.0 intels
    kona 3 w/K Box
    ciprico 4210
    FCP 5.1
    any thoughts?
    thanks,
    j
    Jamie Nabers replied 19 years, 9 months ago 3 Members · 4 Replies
  • Walter Biscardi
    December 13, 2006 at 1:25 am
    If you have audio via SDI then you should have it via RCA. All outputs are hot.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Jamie Nabers
    December 13, 2006 at 1:41 am
    this is where my confusion sets in… i know im supposed to have audio coming through, however, its not. i have plugged the rca’s in to multiple devices to test for sound. nothing.
    thanks,
    j
  • Ken Hon
    December 13, 2006 at 2:52 am
    Aloha Jamie,
    Ok this is going to sound dumb, but try taking the DVI cable that is used to connect the K-Box to the card and reverse it (attach the end that is now on the computer to the K-Box and vice versa). I recall having the same issue and this fixed it.
    Ken
  • Jamie Nabers
    December 13, 2006 at 2:16 pm
    tried that, no luck.
    thanks for the advice though, guess i will call aja directly.
    thanks again,
    j
