Activity Forums AJA Video Systems kona audio output problem
  • kona audio output problem
    Posted by Jas Sekhon on November 28, 2007 at 3:15 pm
    Have a problem while using edit to tape in FCP 6.0.1 i am using kona lhe driver version 4.0 the output i am giving is sdi. Theproblem is while i am using edit to tape in insert mode it is outputting only 2 channel audio while my equirement is 4 channel output. The output setings in my aja control panel is set to sdi also my audio output setting in fcp is set to 4 channels.
    Is there anythingi am missing out the whole machine configuration is
    Macpro 2.66ghz, os x 10.4.9, quicktime 7.3, fcp 6.0.1, kona lhe driver4.0, internally 3×500 gb striped disks, sony dvw-m2000.
    Michael Alberts replied 18 years, 10 months ago 3 Members · 2 Replies
  • Gary Adcock
    November 28, 2007 at 3:25 pm
    [jas22in] “a problem while using edit to tape in FCP 6.0.1 i am using kona lhe driver version 4.0 the output i am giving is sdi. Theproblem is while i am using edit to tape in insert mode it is outputting only 2 channel audio while my equirement is 4 channel output. The output setings in my aja control panel is set to sdi also my audio output setting in fcp is set to 4 channels.”
    I am going to bet that you do not have FCP’s audio outs set correctly in the Audio Tab under system settings.
    The defaults are 5.1 or stereo, so you would need to make a new preset to send the audio as 4 discreet tracks
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Michael Alberts
    November 28, 2007 at 6:13 pm
    In addition to what Gary said, also make sure you have the tracks in the sequence assigned to the proper channels. Right click in the audio track number area of the timeline and assign it to 1,2,3 or 4 (or 1-2 and 3-4 if you set it up for stereo).
    Michael Alberts
    Ambidextrous Productions, Inc.
    http://www.ambidextrous.net
