Activity Forums AJA Video Systems Kona and Premiere scrubbing problem
  • Kona and Premiere scrubbing problem
    Posted by Javi Aledo on August 27, 2011 at 7:11 pm
    Someone using the Kona 3 with Adobe Premiere CS5.0.3 can smoothly scrubbing or it causes delay in updating the image?
    Alguien usa la Kona 3 con Adobe Premiere CS5.0.3 puede realizar scrubbing de forma fluida o le produce retraso en actualizar la imagen?
    Gracias!
    CG, Music, Photography, Programming…
    https://www.JaviAledo.com
    Mikael Bergstrom replied 15 years ago 4 Members · 5 Replies
  • Peter Gruden
    September 6, 2011 at 8:22 am
    I have Kona LHi and I see the same slow scrubbing and general less responsive behaviour. This is in Aja sequence preset, when viewing video on a video monitor. It happens either on Mac or Windows.
    In Premiere sequence preset, the same video scrubs a lot faster.
    I beleive a faster CPU will help.
    Peter
  • Javi Aledo
    September 8, 2011 at 7:23 am
    Hi Peter
    Have you tried it in CS5.5?
  • Cedric Pottier
    September 13, 2011 at 2:45 pm
    I have the same problem with the IO-Express (same spec as LHi) and Premiere CS5.5
    I use a i7 980x CPU so this will not be the issue.
    This delay when scrubbing makes work very difficult to do.
    I hope this will be fixed quickly by AJA.
    cheers,
    Cedric.
  • Javi Aledo
    September 13, 2011 at 9:12 pm
    Thank you!
  • Mikael Bergstrom
    September 22, 2011 at 10:20 am
    The same here to, this is my spec.
    Intel i7 950
    24 gb of ram
    GTX 470
    Adaptec 3085 raid card with 4 x 1TB raid 5 (video disk)
    SSD Intel 160GB G2 as system disk with Win7 64Bit Ultimate
    Adobe CS5.5.1
    Regards
    Mikael
    Mikael Bergstrom
    Six String Studio AB
