Activity Forums Adobe Premiere Pro Kona 3G, Premiere CC – silence or staticy audio sometimes
  • Kona 3G, Premiere CC – silence or staticy audio sometimes
    Posted by Chris Borjis on June 20, 2013 at 5:13 pm
    Premiere CC – MAC
    Kona 3G (latest firmware and 10.4.5 driver and plugins from AJA)
    When I play a timeline, sometimes there is no sound, but
    the audio meters in premiere are moving.
    If I stop then play it usually fixes itself.
    Sometimes it’s static/popping. when it does that I have to reboot
    to get it to go away.
    Anyone else experiencing this?
    If I run final cut pro 7, there are no sound issues.
    On a side note, unrendered sequences no longer have audio sync problem
    when first played, which was a problem on CS 5.5 and CS 6. You’d have
    to stop and restart playback or render it to keep it in sync.
    Not anymore 🙂
    Felipe Fenton replied 13 years, 1 month ago 3 Members · 3 Replies
  • Greg Jones
    June 20, 2013 at 6:27 pm
    I actually had to reinstall 10.4.4 because I was getting a kernel panic when my computer started after installing 10.4.5. I booted into safe mode on my Mac, reinstalled 10.4.4 and it works fine now.
    Greg Jones
  • Chris Borjis
    June 20, 2013 at 7:14 pm
    Well, as usual AJA support fixed me right up within 15 minutes
    of emailing them.
    Here’s the proper settings in case anyone else needs it.
    (I was a little confused by the install instructions)
    System preferences, Sound:
    INPUT: Line in, Audio Line-in port
    OUTPUT: Internal speakers, Built-In
    Premiere Preferences:
    Audio Hardware:
    adobe desktop audio: built-in output
    buffer size: 1024
    output mapping: AJA Kona3G – 0, Slot 2
    Playback:
    Audio Device: AJA Kona3G – 0, Slot 2
    Video Device: AJA Kona3G – 0, Slot 2 (checked)
  • Felipe Fenton
    August 1, 2013 at 10:00 pm
    Thanks so much for posting that. It fixed it right up!
