Activity Forums AJA Video Systems kona 3 playback question
  • kona 3 playback question
    Posted by Dom111 on July 17, 2006 at 6:00 pm
    With a kona 3 card installed and set to SD SDI o/p viewed on a stand alone monitor, during playback of either the source clip or the sequence is it normal that the FCP source and playback monitors don’t update? All I get is playback video on the external monitor, the fcp windows don’t show moving video at all.
    Any ideas? Is my Kona 3 card playing up?
    Thanks in advance,
    Dom.
    Arnie Schlissel replied 20 years, 2 months ago 3 Members · 2 Replies
  • Gary Adcock
    July 17, 2006 at 6:18 pm
    [dom111] “With a kona 3 card installed and set to SD SDI o/p viewed on a stand alone monitor, during playback of either the source clip or the sequence is it normal that the FCP source and playback monitors don’t update? “
    no it is not
    your setup is not correct !!!
    make sure to use an easy set up and make sure you have your video out set to all frames.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Chicago, IL
  • Arnie Schlissel
    July 18, 2006 at 2:12 pm
    It sounds like you have “Mirror video on the desktop” checked off in the AV settings. Look through the tabs in the AV settings to check, & turn it back on.
    Arnie
    Now in preproduction: Peristroika (Cosmological Congress), a film by Slava Tsukerman
    https://www.arniepix.com
