Activity Forums AJA Video Systems kona 3 no sound output
  • kona 3 no sound output
    Posted by Ahmed Samir on May 22, 2009 at 4:51 pm
    i have aja kona 3 from 3 days
    and i capture from digibeta with sdi
    the proplem is i can`t hear sound output from my speaker
    i see wave in final cut when i digitize but i don`t hear the sound
    and of course i switch the sound from osx to aja and from final cut to aja
    i used this speaker ( Studiophile BX5a Deluxe ) with xlr input
    please help i can`t work and i try all i know
    thanks
    Bob Zelin replied 17 years, 4 months ago 7 Members · 14 Replies
  • 14 Replies
  • Tom Matthies
    May 22, 2009 at 5:13 pm
    I’ve had luck by zapping the P-RAM while restarting.
    Hold down Command, Option, P, and R while Mac is starting up.
    Worth a try.
    My Kona 3 did this sometimes until AJA replaced it under warranty.
    Thanks AJA!
    Tom
  • Ahmed Samir
    May 22, 2009 at 5:39 pm
    thank you
    i will try and tell you
  • Jesse Green
    May 22, 2009 at 5:40 pm
    Make sure your digitize window is not open, i’ve been fooled this way many times.
    PowerPC G5, 4 x 2.5 GHZ, 16 GB Ram, Kona 3, Dual Cinema 23′.
    ProTools HD 1 Accel Core Card, 192 I/O, D-Command Main, Neumann TLM 193, PowerPC G5, 2 x 2 GHZ, 4.5 GB Ram.
    17′ Macbook Pro, 2.6 GHz, Intel Core 2 Duo, 6GB Ram.
    24′ iMac, 3.06 GHz, 4 GB Ram.
    PowerPC G5, 2 x 2 Ghz, 6 GB Ram.
    Leopard 10.5.x
  • Ahmed Samir
    May 22, 2009 at 5:47 pm
    ok but i want to know if this speaker ( Studiophile BX5a Deluxe ) analog or digital
    and if analog , can i plug it in breakout box and hear audio
    thanks so much about your time
  • Ahmed Samir
    May 22, 2009 at 5:49 pm
  • Craig Thomas quinlan
    May 22, 2009 at 6:03 pm
    Just saw your last post.
    Yes. Those speakers are fine. You should run the rca analog outs of the BOB to the channel ins of a mixer, and the out of the mixer to your BX5As.
    May 22, 2009 at 6:11 pm
    Are you running this through a mixer? Try rerouting the rca outs of your breakout box straight into the bx5as. If you get sound, check the cabling and setup of the mixer.
    Are you sure your speakers are working? Come off the built-in output of the mac straight into your speakers and see if they work.
    As always, double-check your settings and make sure that the audio is being routed to the kona.
  • Ahmed Samir
    May 22, 2009 at 6:19 pm
    yes i try to plug digibeta direct to speaker and i hear sound so good
    and my setting is routed to aja kona from osx and from final cut too
    but i think this speaker is analog not digital
  • Ahmed Samir
    May 22, 2009 at 6:22 pm
    thanks
    but i want to know
    why i can`t plug rca from breakout box to BX5AS directly
    why i want to mixer between them ?
  • Jeremy Garchow
    May 22, 2009 at 6:44 pm
    [Ahmed Samir] “i used this speaker ( Studiophile BX5a Deluxe ) with xlr input “
    The XLR in and outs of the Kona breakout box are digital AES/EBU only. The XLR connections are not analog audio connections.
    You need to hook up the analog RCA outputs of the break out box to the analog inputs your speaker.
    Jeremy
