Did you follow these steps?…..:
[JeremyG] “Select the HD easy setup (control-q) within FCP so that the frame buffer is correct (in your case 720p). Now, open the Kona control panel and control click the output that you want to send the down convert to (SDI, SDI2 OR ANALOG). When you control click you will see a drop down menu, and in the secondary section select the SD format you need (ie 525i 29.97 or whatever). FCP should be in HD mode, and the control panel takes care of the rest.”
First, it appears if you are using the generic DVCPro HD 30p easy setup, which is for firewire use only. You need to use the AJA Kona3 720p30 DVCPRO HD Varicam setup If you don’t see it select the ‘show all’ checkbox in the easy setup dialog box by hitting control-q and then check the show all box in the top right corner. It might say 29.97 instead of 30. Come to think of it, I am not sure if the Kona easy setups have a 30p preset, you might have to make one. At any rate, choose the AJA KONA setup, and then follow the steps I quoted above. If you need help in making a new easy setup, post back. I usually work in 60 or 24p so I am not sure in 30p is ‘built in’ to the presets.
Jeremy
