Activity Forums AJA Video Systems Kona 3 Digital Audio?
  • Kona 3 Digital Audio?
    Posted by Dean Brennan on August 5, 2008 at 2:21 pm
    I had a question about the audio inputs on the Kona 3. I have an HD-SDI feed from our routing system to my editing bay that provides a high definition signal. The problem is we still have analog audio coming into the edit bay and I don’t think I can input stereo XLR to the Kona 3 card because the Kona 3 just has Digital EAS Audio inputs.
    Does anyone know of any work arounds to get my audio with my video or maybe a good analog to Digital EAS converter? Am I on the right track?
    Thanks ahead of time!
    Dean
    Dean Brennan replied 18 years, 1 month ago 4 Members · 4 Replies
  • Walter Biscardi
    August 5, 2008 at 3:27 pm
    [Dean Brennan] “The problem is we still have analog audio coming into the edit bay and I don’t think I can input stereo XLR to the Kona 3 card because the Kona 3 just has Digital EAS Audio inputs. “
    So you just need the audio into suites for playback and not for capture because obviously you’re capturing the audio embedded via HD-SDI. The Kona 3 has a pair of RCA analog audio outputs that you can easily feed to your edit suite. This is what we’re now doing.
    AJA also has the ADA-4 A/D audio converter as well.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Arnie Schlissel
    August 5, 2008 at 10:13 pm
    To clarify, you need the K3 breakout box to get the stereo RCA analog audio outputs. The card itself has no analog audio.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Mathieu Marano
    August 6, 2008 at 2:51 pm
    I use the ADA4 AJA mini converter for that purpose. It works fine:
    https://www.aja.com/html/products_converters_ADA4.html
    Mathieu Marano
    online editor – motion graphics – Post-prod director
    Directeur technique de post-production
    Le Bureau de post production
    Administrator of the Montreal Final Cut User Group
    http://www.finalcutmtl.org
  • Dean Brennan
    August 11, 2008 at 2:52 pm
    Cool. I think the mini converter will do the trick. Thanks for all of your help!
