Activity › Forums › AJA Video Systems › Kona 3 – bet you have not seen this problem !
  • Kona 3 – bet you have not seen this problem !
    Posted by Bob Zelin on November 14, 2009 at 12:57 am
    AJA didn’t have the answer.
    ProRes422 and ProRes422HQ works fine – so don’t be a wise ass.
    Input HD-SDI from HD1400, using FCP 7.0.1, with OS-X 10.6.2.
    DVCProHD 59.94. If you capture for 10 – 15 seconds, everything works fine – the 1280x whatever becomes the 960x whatever and it works perfectly.
    If you capture at DVCProHD for over 3 minutes, the SIZE changes to 640×330 (that’s right 330). Switch to ProRes, and NO PROBLEMS, and yes, this is a clean install, and yes, I trashed every preference (including Quicktime) that I could find ?
    Anyone that can answer this gets a cookie.
    Bob Zelin
    Gary Adcock replied 16 years, 10 months ago 5 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    November 14, 2009 at 1:34 am
    [Bob Zelin] “If you capture at DVCProHD for over 3 minutes, the SIZE changes to 640×330 (that’s right 330). Switch to ProRes, and NO PROBLEMS, and yes, this is a clean install, and yes, I trashed every preference (including Quicktime) that I could find ?”
    I see this often with ProRes HQ which is why we stopped capturing to that format, although it’s always 640×360. AJA has told me they can never reproduce the problem.
    We also get this exact issue on rare occasions with ProRes.
    Have not seen it with DVCPro HD.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” now in Post.
    Creative Cow Forum Host:
    Apple Final Cut Pro, Apple Motion, Apple Color, AJA Kona, Business & Marketing, Maxx Digital.
    Blog!
    Twitter!
  • Gary Adcock
    November 14, 2009 at 4:31 pm
    [Bob Zelin] “Anyone that can answer this gets a cookie.
    you do not say which machine?
    Are you running on a first gen Quad intel machine with 4 gigs of RAM??
    or a first gen Nehalem octo core with more than 8 G RAM?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Bob Zelin
    November 14, 2009 at 11:03 pm
    Gary writes –
    REPLY – yes Gary – this machine is the one you just described. I have two like it, doing the exact same thing.
    It troubles me that Walter and I have BOTH had the original “audio popping problems” with DVCProHD (we never heard of that problem), and now, both Walter and I have the same problem with capture, and changing frame size (we never heard of that problem).
    Bob Zelin
  • Gary Adcock
    November 16, 2009 at 2:20 pm
    [Bob Zelin] “REPLY – yes Gary – this machine is the one you just described. I have two like it, doing the exact same thing. “
    There is an apple firmware update that was supposed to fix this- it is specific to that machine also.
    let me look…
    gary adcock
    Studio37
    Chicago, IL
  • Bob Zelin
    November 18, 2009 at 1:18 pm
    Gary –
    I am sitting here, holding my breath to get the “firmware update” to this issue. If you have the answer, then you get a prize !
    Bob Zelin
  • Mitch Ives
    November 19, 2009 at 3:34 pm
    I’ll echo Walter’s comment. I’ve seen that using Pro-Res, which is why I stopped using it some time ago… especially Pro Res HQ.
    Now with FCS3, we’re trying Pro-Res again (we’d like to use it). Now I’ve discovered a problem rendering where I get a “file already exists” error and it won’t render sections that were previously rendered. So far, I can’t reproduce that using something other than Pro Res (an admittedly unscientific test).
    FWIW, I have been experiencing some audio popping too… I thought we were past that…
    Mitch Ives
    Insight Productions Corp.
    mitch@insightproductions.com
    http://www.insightproductions.com
  • Mark Maness
    November 19, 2009 at 7:34 pm
    Let me ask you this, Bob…
    With regards to the audio popping issue.
    Do you have the VANC option checked or unchecked and what version of the AJA driver do you have?
    I had this issue with the 7.0 driver but since upgrading to the 7.0.1 driver, the popping has seemed to have gone away with the VANC checked.
    BUT…. Now, I’m seeing other issues that I did not have like my previews are no longer realtime and when your timeline has a area where there is no video but has audio and then it has more clips after that, the video will slow down then speed up as to catch up with the CTI.
    Puzzling…
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Gary Adcock
    November 20, 2009 at 1:09 am
    [Bob Zelin] ” am sitting here, holding my breath to get the “firmware update” to this issue. If you have the answer, then you get a prize ! “
    bob.
    I no longer have access to the update- talk to one of the service guys you know- it was specific to the late 2008 / early 2009 machines
    gary adcock
    Studio37
    Chicago, IL
