Activity Forums AJA Video Systems Kona 3 Audio Output
  • Kona 3 Audio Output
    Posted by Legend on June 3, 2006 at 6:10 pm
    I recently installed a K3 card in my G5. I have the audio out going into A Mackie 1202 mixer but I am not getting audio.Do I need some sort of converter? or is there a mixer that accepts the AES audio will the onyx work Please Advise.
    Legend replied 20 years ago 3 Members · 3 Replies
  • Walter Biscardi
    June 3, 2006 at 6:31 pm
    The XLR audio is AES/EBU digital audio. If you want to use these feeds, you can pick up an AJA ADA4 A/D converter to convert the digital to analog. I use a Flying Cow converter in one room and the ADA4 in the other.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Bob Zelin
    June 3, 2006 at 9:14 pm
    Hi Legend –
    If you own the Kona K3-Box with your Kona 3 board, it has two analog RCA outputs on it, which are monitor outputs. This product from AJA costs only $299, and will allow you to plug directly into your Mackie 1202 LINE INPUTS (don’t use the XLR inputs on your 1202 – they are MIC inputs). So you will need to get RCA to 1/4″ TRS audio cables to hear something. Everything else that Walter has mentioned will work as well, but will probably cost more money.
    Bob Zelin
  • Legend
    June 6, 2006 at 7:34 am
    Thanks for the info guys
