Activity › Forums › AJA Video Systems › Kona 2 + Panasonic D5 deck
  • Kona 2 + Panasonic D5 deck
    Posted by Michael Garber on April 14, 2006 at 5:38 pm
    Hi All,
    I’m going to be doing onlining something using D5. Up until now I’ve only used HD-CAM or HD-CAM SR. Has anyone used a D5 deck to capture and lay off 10-bit HD uncompressed with the Kona 2? If so, any pitfalls? I believe the footage is 23.98.
    Michael
    Erik Hansen replied 20 years, 5 months ago 3 Members · 2 Replies
  • Greg Jones
    April 14, 2006 at 6:48 pm
    I used this deck to digitize from on a project last year and I had no problems at all.
    Greg Jones
    D7,Inc.
    Orlando,Fl.
    https://www.d7-inc.com
  • Erik Hansen
    April 15, 2006 at 12:16 am
    Just check to make sure that you are using the Panasonic RS-422 device control settings. Like any deck you should also calibrate it to make sure that you are getting accurate pulls & layoffs. I use a D5 almost daily at work.
    Best,
    – Erik
