Activity › Forums › AJA Video Systems › Kona 2 output to HDCAM F500 VTR error
  • Kona 2 output to HDCAM F500 VTR error
    Posted by Steven Escobar on September 9, 2006 at 3:22 pm
    I’m trying to output a feature from FCP5 with Kona 2 card @ 23.98 8 bit to a HDCAM F500 but when I go to Edit to Tape it gives me a Incompatible compression settings error. It also says the following: “You may have attempted to output a clip with compression settings that do not match the current output settings. Try nesting the clip in a sequence the correct settings.”
    I’ve tried that and even looked in the audio/video settings in FCP and tried to change the name but no good. Anyone have this problem? Anyone have a solution? HELP I need to output with TC matching the sequence for a festival and I only have the deck this weekend.
    Steve
    Steven Escobar replied 20 years ago 2 Members · 2 Replies
  • Jeremy Garchow
    September 9, 2006 at 11:29 pm
    Close the sequence, open the edit to tape window, set up your in point and necessary settings and then drag the sequence from the browser to the Edit to tape window and let go when you hover over assemble.
    Jeremy
  • Steven Escobar
    September 10, 2006 at 5:40 am
    Thanks, I knew it was pretty simple just haven’t output in awhile.
