Activity Forums AJA Video Systems Kona 2 or Kona LH
  • Kona 2 or Kona LH
    Posted by Jjbriquet on April 12, 2007 at 9:55 pm
    Hi I have a Dual G5 1.8 and I can get either a Kona 2 or Kona LH for about the same price, which one should I get and why.
    Basically I will be using it for HDV editing in DVCProHD format, some SD uncompressed projects from time to time (I really need to be able to output only 1 stream of SD 10bit uncompressed)
    Also, can I capture HDV via RGB analog into LH to DVCProHD?? This way I wold not need a converter for the time being.
    Lots of questions so thank you in advance for any advices,
    JJ
    Jjbriquet replied 19 years, 5 months ago 3 Members · 3 Replies
  • Bob Zelin
    April 13, 2007 at 1:35 am
    the LH will allow you to bring in the analog HD right into the board – the Kona 2 will require a converter. The LH is the right choice for you, at this time.
    Bob Zelin
  • David Roth weiss
    April 13, 2007 at 1:37 am
    The LH has balanced analog audio I/O. I think you’d be quite happy with it.
  • Jjbriquet
    April 13, 2007 at 3:34 am
    Sounds Great, thanks for the info. I will go with the LH then – JJ
