Activity › Forums › AJA Video Systems › Kona 2 downconvert from HD to 625 results in buzzing luma / ‘gamut error’
  • Kona 2 downconvert from HD to 625 results in buzzing luma / ‘gamut error’
    Posted by Richard O on August 24, 2006 at 9:45 am
    Hello there
    In trying to track down why my playouts to digibeta are resulting in illegal white/black values, I’ve discoverered the following:
    When the Kona 2 card downconverts 1080i material to standard def 625/25, it introduces a ‘buzzing’ at the top and bottom of the waveform parade, which is pushing my luma values above the legal level. The waveform monitor also displays a ‘gamut error’ message.
    But when 625 is set as the native format (frame buffer), the problem goes away and all is fine and legal with no buzzing at all.
    This was happening with my 1080i output from Final Cut Pro – but it also happens with the Kona’s own test pattern, regardless of FCP involvement. (output is SDI, no external ref generator being used)
    My supplier and AJA themselves thought it was a faulty card – but I’ve now replaced it and the problem persists.
    Could anyone fire any more suggestions at me to try – I’m running out of ideas and I need to get my HD programmes out to digibeta!
    many thanks
    Richard Overall
    Itamar Kool replied 20 years, 1 month ago 2 Members · 1 Reply
  • Itamar Kool
    August 24, 2006 at 2:11 pm
    Did you check your Video Play back settings in FCP? If they are not right, it can result in strange things
    Kool En De Anderen
    dual 1.8 gig G5/Mac OS 10.4.6/Kona 2/Hugh 800 G diskarray, fibrechannel/FCP 5.02/AE 7 Pro
    http://www.koolendeanderen.nl
