Activity › Forums › AJA Video Systems › Kona 2 – capture HDV as DVCPROHD via firewire?
Posted by Sterling Noren on November 27, 2006 at 5:50 pmPardon me for asking this but I didnt find the answer I searched for…
I understand that the Kona 3 allows you to capture HDV as DVCPROHD via firewire. Does the Kona 2 allow this as well? (if so, how does the setup work…I dont seem to see anything that indicated this in the presets)
Thank you.
Sterling Noren
WideWorld HD ProductionsHd Freak replied 19 years, 9 months ago 9 Members · 14 Replies -
Gary Adcock
November 27, 2006 at 8:29 pm[WideWorld HD] “I understand that the Kona 3 allows you to capture HDV as DVCPROHD via firewire.”
I do not know where you got this- but you CANNOT capture via FW with the Kona 3 or Kona 2 both of these cards capture baseband video over HDSDI not over FW.
you can use a HD10AVA or HD10A converters with the either Kona 2 & Kona 3 or use the Kona LH card to capture HDV into the DVCPROHD codec over the analog video out from the camera or deck
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Bob Zelin
November 28, 2006 at 12:47 amDavid and Justin –
why are you discussing the I/O. Sterling in his original question NEVER mentioned the I/O – yet you are discussing the I/O, and of course, this is completely incorrect. The I/O is Standard Def only, as you can easily see from simply reviewing the web site at http://www.aja.com.Bob Zelin
Bob Zelin
November 28, 2006 at 12:49 amHi Sterling –
I don’t know what equipment you own, but I am going to ASSUME that you own an HDV camera or HDV VTR. If you have a Kona LH or Kona LHe, you can input the analog HD signal into FCP as DVCProHD – NOT VIA FIREWIRE !!!!!! Via the BNC connectors. FORGET FIREWIRE – make believe it does not exist.For the Kona 2 or Kona 3, if you own a HDV camera or HDV VTR, purchase the AJA HD10AVA, which will transcode the analog HD Y Pb Pr signal into HD-SDI, and embed the analog audio, so you can put this directly into your Kona 2 (or Kona 3).
FORGET FIREWIRE exists (unless you own an AJA I/O box, and use it for this application only).
Bob Zelin
Sterling Noren
November 28, 2006 at 1:23 amThanks Bob – Its pretty much as I assumed – capturing HDV as DVCPROHD via FireWire is not possible. I always knew this but read some posts that indicated otherwise so now I will shut up and get back to work.
I am considering purchasing the LHe for my home studio and will be capturing HDV as DVCPROHD via the analog outputs on my camera. For audio I will run the camera outputs through a mixer and convert to XLR cables for the Kona input. And for device control I would still be using FireWire. Are there any issues here Im missing? Audio sync….will it work okay this way?
Thank You
Sterling Noren
WideWorld HD Productions -
David Battistella
November 28, 2006 at 5:31 amAn easy way to remeber this is that Firewire captures are always data stereams and can not be converted VIA firewire.
WHEN RECORDING VIA FIREWIRE
DV IS DV
HDV IS HDVDVCPRO HD is DVCPRO HD
DV50 is DV50Technically Firewire is a data stream or a digital file transfer.
The only way to capture to alternate codecs is to capture via the HD-SDI Stream, when the video is coming in that wawy it can be captured in various formats.
Gary was spot on in his inital reply.
FYI the I/O uses the firewire Bus to transfer data. It is basically an IN OUT conversion box between either A to D or D to D depending on which box you buy. It acts like a video capture device on the firewire bus instead of on an internal PCI bus.
Whew! Bob you are right, threads get confusing for no good reason. how did the I/O get mixed up in this.
David
Peace and Love 🙂
Richard Dee
November 28, 2006 at 10:43 pmisn’t there a new Sony HDV deck that has HD-SDI out?
If so, wouldn’t this be the best way – to get it into the Kona and capture as
DCpro HD?
