Activity Forums AJA Video Systems Kona 2 and FCP 5/Tiger slow to update video…
  • Kona 2 and FCP 5/Tiger slow to update video…
    Posted by Tunaking on August 19, 2005 at 7:02 pm
    Is it just me or is the Kona 2 very slow in updating the video out of the card when working in Uncompressed SD or HD. Like when I try to color correct uncompressed footage with the 3-way color corrector, the canvas screen updates immediately but the video output on the Kona 2 doesn’t update in the longest time (ten seconds or more). It just makes color correction a nightmare. I don’t remember it being so slow in FCP 4 HD.
    Is there a way to make it faster?
    Tunaking replied 21 years ago 4 Members · 4 Replies
  • Walter Biscardi
    August 19, 2005 at 7:46 pm
    Did you perform a clean install of Tiger, run all the updates, then install FCP 5.0 clean and then run all the updates? If you simply upgraded your OS and FCP, you’ll run into a lot of problems and slow downs.
    Also ensure you’re running the latest Kona 2 drivers.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • David Battistella
    August 19, 2005 at 8:33 pm
    I have also noticed sluggish response for the three way CC.
    I used to use the option F12 key to refresh frames but it seems that the dashboard has taken over that keyboard shortcut.
    This is on a brand new, clean install of Tiger and FCP 5.0. On my Aurora system the 3wayCC response is immediate.
    David
  • Jeremy Garchow
    August 19, 2005 at 8:47 pm
    Go into your system preferences for dashboard and you can turn off the dashboard keyboard shortcuts to get your FCP functionality back.
    I do notice some delay, but usually if I arrow back once and then forward it updates the display immediately and holds until I go to the next clip.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 4.5 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Tunaking
    August 23, 2005 at 10:59 pm
    I’m using a clean install of Tiger and the newest driver. Xserve RAID for Storage. The F12 hint is a good one. Wish it were a lot faster.
