Activity Forums Apple Final Cut Pro Legacy Kodak Zi8 Import
  • Kodak Zi8 Import
    Posted by Michelle Mazz on November 8, 2009 at 5:03 pm
    Hi. I’m new to this forum so I hope this isn’t a stupid question. I have some footage shot on the Zi8 in 720p 60fps. When I try to import it into FCP I get an access denied error but not on all footage, just some of it. Anyone have any ideas of why and how to resolve this. They have .mov extensions and the codec is H.264.
    Michelle
    Jeremy Ball replied 16 years, 8 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    November 8, 2009 at 9:31 pm
    Try transcoding it to ProRes instead of working natively in h.264. H.264 is a delivery format not really supported all that well in FCP. Import it all into Compressor, then export it as ProRes using the same frame size and frame rate.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Michelle Mazz
    November 9, 2009 at 11:12 pm
    Thank you so much. It worked!
    Michelle
  • Donnie Wagner
    November 27, 2009 at 12:55 am
    Jerry,
    Once i’ve converted to ProRes, can the 60 fps footage be dropped into a 24fps timeline for slow motion?
    Donnie
  • Jeremy Ball
    December 8, 2009 at 7:18 pm
    You can do this easily in Cinema Tools. All it does is conform the clip to play back at 24 fps, it does not actually convert it so no artifacts. 60fps to 24fps should give you a nice slow mo.
    One note of caution, make sure to create copies of your clips you want to change the frame rate of in Cinema Tools. Once you change the clip frame rate it can not be undone.
