Activity Forums Adobe After Effects knoll spectacular flickering – can’t stop it!?!?!
  • knoll spectacular flickering – can’t stop it!?!?!
    Posted by Scott G on May 8, 2006 at 4:58 am
    hey guys,
    is there a trick to stopping the flicker that occurs when using small location points with knoll spectacular? actually, even when the location dots are quite large, it seems to flicker when there’s a camera move. does this plugin not use subpixel sampling? it almost looks like the size of the location dot affects the brightness of the flare.
    this is ridiculous, please help.
    thanks,
    scott.
    Scott G replied 20 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
