Activity Forums Adobe After Effects Knoll Light Factory Alpha Problem
  • Knoll Light Factory Alpha Problem
    Posted by Chris Mathews on June 7, 2016 at 8:15 pm
    So, I’ve made this lower third design in AE using a lot of Knoll Light Factory lights. When I check the background is seemed to be transparent, checkboard appear, but when I render the TGA Sequence it shows black. I turned RGB+Alpha and the bit depth is 32 bit. Does anyone have any idea what the problem might be?
    Chris Mathews replied 10 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
