Activity › Forums › Adobe After Effects › Knoll Light Factory 2.5.2 crashes
  • Knoll Light Factory 2.5.2 crashes
    Posted by Michael Duff on June 20, 2008 at 12:14 am
    Hi everyone .. we just purchased KLF 2.5.2 yesterday and it is crashing all over the place .. We are running it on CS3, and have tried on a G5 and macPro with the same results … we get an error saying “After Effects cannot invoke the plug-in Knoll Light Factory” … then it crashes …
    We are applying the plug-in to quite a complicated HD (1920×1080 25fps) composition which also has in it other lens flares, blurs, Magic Bullet Look Suite… we apply the flare to a black solid and then screen it … although the plug-in doesn’t seem to crash if I just apply it to a different composition with just a layer in it …
    does anyone know of conflicts KLF has with other plug-ins? or what could be causing this? I’ve tried it with GPU on and off … multiprocessor on and off .. and they all crash …
    Greg Neumayer replied 18 years, 1 month ago 3 Members · 2 Replies
  • Charles Meadows
    June 20, 2008 at 12:21 am
    [Michael Duff] “KLF 2.5.2 is crashing all over the place .. We are running it on CS3, and have tried on a G5 and macPro with the same results … we get an error saying “After Effects cannot invoke the plug-in Knoll Light Factory” … then it crashes … We are applying the plug-in to quite a complicated composition which also has in it other lens flares, blurs, Magic Bullet Look Suite … does anyone know of conflicts KLF has with other plug-ins? I’ve tried it with GPU on and off … multiprocessor on and off .. and they all crash …”
    Red Giant strikes again. Sloppy code and long dry spells between fixes.
    Sorry I don’t have a fix but I really doubt there is one. It’s why I avoid RG software like it was the plague.
    CM
  • Greg Neumayer
    August 26, 2008 at 3:47 am
    I’m not explicitly having a Knoll crash, but AE is unexpectedly quitting during rendering, and in the “Send to Apple” report, there are a whole bunch of Knoll Lens flare lines near the top of the code. Does this mean my problem is with Knoll?
    Also noteworthy, this is only happening in 16 bit.
    I’m currently using 2.5.1, hoping that the move to .2 might solve my problems.
    -Greg
    Antifreeze Design
    https://www.antifreezemotiongraphics.com
