Activity Forums Adobe Illustrator knife and scissors tool ?
  • Les Nemeth
    March 18, 2010 at 10:40 pm
    The knife and scissors tools are hiding behind the eraser tool (in CS4).
  • Les Nemeth
    March 18, 2010 at 10:43 pm
    If you closely look at the image on that link, you’ll find it is correct. On the tools panel, from label “H”, you’ll see a long line going up to the eraser tool.
    Also, in the description text, it is correctly showing under “H – Slicing and cutting tools”. There you’ll see the the scissors and knife is listed under the eraser.
