Activity › Forums › AJA Video Systems › KiPro – stopped recording – major complaints
Gerhard Riesenhuber replied 13 years, 9 months ago 19 Members · 57 Replies
Gary Adcock
February 17, 2012 at 1:44 pmBtw. Alexa also triggers REC with Canon XF/C300 Metadata Setup
That setting really has nothing to do with the REC trigger, Alexa has been able to trigger a record over RP188 since V2 of camera software allowed a start/ stop pulse. ( over 14 months)
I want proper, accurate camera file naming structure from Alexa, other recorders can do it.
gary adcock
Studio37Post and Production Workflow Consultant
Production and Post Stereographer
Chicago, ILhttps://blogs.creativecow.net/24640
follow me on Twitter
@garyadcock -
Gerhard Riesenhuber
February 18, 2012 at 6:56 pmTriggering the KiPro with Alexa only works with EdgeCode,
with a free running timecode it is not possible.
Does this change with the new v3 firmware of the KiPro? -
Steve Cocklin
February 18, 2012 at 8:04 pmIt does now with the PMW F3 using the C300 setting in the Mini.
Gary Adcock
February 18, 2012 at 10:02 pmTriggering the KiPro with Alexa only works with EdgeCode,
with a free running timecode it is not possible.I have used KiPros to automaticly record from Alexa’s HDSDI output since the first ProRes model released as a test platform in June 2010, I have worked with every version of the camera and KiPro firmware since that time without incident.
My workflows do not use edge code or free run TC, I usually work with external TC, so the change in TC when we start rolling triggers the record when the unit is set properly.
The reason it is working for you is that when you have edge code on in a free run situation, that is where the Start pulse is indicated within the RP188 functionality.
since v2 of the camera firmware, Arri added an SDI pulse in the menus that facilitated all external recorders with the ability to trigger recording, note you need to have recording media in the camera to achieve start/stop.
gary adcock
@garyadcock -
Gerhard Riesenhuber
February 23, 2012 at 4:01 pmHi Gary,
It’s not working for me, because we always use free run timecode.
As far as I’ve seen the RP188 functionality only works with a not
free running timecode.The question is if the SDI pulse (REC flag) also triggers the
AJA KiPro (in a free run situation)?Best regards,
Gerhard -
Sam Martin
February 28, 2012 at 9:53 amDear Gerhard,
It’s all on the AJA website… Sony SxS Pro Cards 32GB/64GB not supported (I tried them nevertheless). see https://www.aja.com/pdf/KiPro_qualified_ExpressCard34_Media.pdf
And yes: If you set Alexa to SDI flag, but choose out of KiPros “Metadata sets” Canon XF or C300
Alexa triggers the KiPro with freerun TC.Regards,
SamSam Martin * videoworks
Leonardo Lottum
November 23, 2012 at 5:21 pmNow that the Alexa is integrated in the 3.1 firmware the Rec flag works normally. But strangely now I can’t rec myself when the camera is not running and the ki pro is in the Alexa meta data mode.
I suppose the Alexa is sending constantly rec stop flags?!???(I have not much of clue of the flag mechanism)
Because always when I press rec it starts and stops instantly.
Tc mode is free run and the arm record is set on red key!
Thanks people
Leo -
Gerhard Riesenhuber
November 25, 2012 at 6:00 amHi Leo,
I already asked AJA about this behavior. They said, that’s how it’s supposed to be.
I requested to also be able to do manual recording in this mode (or an “extended”
one), as the KiPro is often used as a recording unit for video village and rehearsals
also have to be recorded, when the camera is not recording.I’m also interested how the REC flag mechanism works.
All the best,
Gerhard -
Leonardo Lottum
November 25, 2012 at 9:51 amOh that’s a pity. I also contacted them because of that and they didn’t respond yet because of thanksgiving.
It’s strange that this is supposed like this.
Also in the manual it says “the Rec Key is always a viable selection even when the Camera Data parameter is selected”
I don’t know, but that sounds like it is supposed to work always isn’t it?
