Activity › Forums › AJA Video Systems › KiPro Mini how many channels of audio can it record
  • KiPro Mini how many channels of audio can it record
    Posted by Brad Bussé on January 3, 2011 at 11:54 pm
    I’m considering a KiPro mini for use with recording the HD-SDI output of an AF100. Can the KiPro Mini simultaneously record all of the audio channels being sent out of the AF100 over the SDI, as well as the 2 XLR inputs on the KiPro Mini unit itself?
    Jeremy Garchow replied 15 years, 9 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    January 4, 2011 at 12:22 am
    If the mini is anything like the big Ki Pro, you can only recored wither digital or analog audio, and not both. I am sure the mini will handle the 2-4 audio channels that the af100 will send.
    According to the specs, it will record 8 channels embedded:
    https://www.aja.com/products/kipro/ki-pro-mini/ki-pro-mini-specs.php
    Jeremy
  • Marc Colemont
    January 4, 2011 at 7:01 pm
    But it wil not record both. It’s either the embeded SDI audio or the XLR’s
  • Jeremy Garchow
    January 4, 2011 at 7:05 pm
    [Jeremy Garchow] “If the mini is anything like the big Ki Pro, you can only recored wither digital or analog audio, and not both.”
    Yeah, sorry about that typo, should have been:
    If the mini is anything like the big Ki Pro, you can only record either digital or analog audio, but not both.
    Jeremy
