Activity Forums Maxon Cinema 4D Kind of a newbie question: trying to reduce a kitbashed model
  • Kind of a newbie question: trying to reduce a kitbashed model
    Posted by Steve Ra on December 5, 2018 at 12:44 am
    Hey all,
    I am having some trouble reducing a heavy model I kitbashed. Around 500k polygons. I am attempting to use this in an animation. Hence, I would like to reduce it as much as possible without losing too much detail.
    What do you suggest? Decimate? Bake it down (tried this but I think I did it improperly), or do I retopo it??
    Any help will be much appreciated thanks!
    Harry Hoag replied 7 years, 9 months ago 3 Members · 4 Replies
  • Harry Hoag
    December 5, 2018 at 9:23 am
    Can’t you just use a proxy, lower poly model for animating with and then use the high detail one at render time?
  • Steve Ra
    December 5, 2018 at 9:30 pm
    Hey,
    thanks for response. I was thinking about doing that. I was just curious if there was a way to bring the current model down.
  • Brian Jones
    December 5, 2018 at 10:00 pm
    depending on the version of C4D you have the Polygon Reduction Tool might be a way to go
  • Harry Hoag
    December 6, 2018 at 9:38 am
    I wish there was some kind of smart poly reduction tool but I always find the automatic ones a bit useless for accurate work. Might have to be manually remodelled. Or maybe try zBrush or something more specialised like that? I don’t use it so I’m not sure.
