Activity Forums VEGAS Pro Killing computer but still slow preview
  • Killing computer but still slow preview
    Posted by Philippe Gaudens on April 7, 2014 at 3:58 pm
    I just bought a computer with killing config:
    DUAL Xeon E5 2697v2
    64GB of RAM ECC
    GeFroce GTX Titan Black
    I still can’t preview my footage (with Sony GPU optimized video FX) in Full res and good quality !!
    For example, just a blur between to videos can’t be realtime preview !
    It is fluid only when I put half res and draft !!
    Is there something I missed ?
    John Rofrano replied 12 years, 5 months ago 4 Members · 16 Replies
  • 16 Replies
  • Graham Bernard
    April 7, 2014 at 5:06 pm
    What we are missing is what IS your material and WHAT are your project settings.
    G
  • Philippe Gaudens
    April 7, 2014 at 5:36 pm
    I already give my material… But I can be more precise.
    2 x 30″ displays
    Working on SSD
    Sony Vegas Pro 12
    My project settings are:
    Full HD 1920*1080 24fps
    progressive scan
    Square
    no rotation
    Stereoscopic 3D: Off
    Pixel format 8
    Full-res rendering quality: Best
    Motion blur type: Gaussian
    Deinterlace: none
    Do you need more information I could have forget ?
  • Graham Bernard
    April 7, 2014 at 5:55 pm
    What is the MEDIA that you are editing?
    G
  • Philippe Gaudens
    April 7, 2014 at 7:32 pm
    I edit videos from CANON 5D markIII
  • John Rofrano
    April 7, 2014 at 7:41 pm
    [Philippe Gaudens] “GeFroce GTX Titan Black”
    That’s your problem right there. Vegas Pro 12.0 doesn’t take full advantage of the new Kepler cards. So this card will perform, worse than a old 5 year old GTX 570. So while your machine may be killer… Vegas Pro can’t take advantage of the GPU that you selected.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Graham Bernard
    April 7, 2014 at 9:09 pm
    Tnx John!
    G
  • Norman Black
    April 7, 2014 at 10:26 pm
    [Philippe Gaudens] “I edit videos from CANON 5D markIII”
    I don’t have a 5D MkIII and probably not others. We need to know what the exact video format is. What does the MediaInfo utility say about those files. It is a free program you can download.
    I do have a Canon 7D and they are MOV files with AVC video at 44Mbps, PCM audio for 1080p30. I can put a gaussian blur on one of these clips and it plays back fine GPU ON or OFF with one exception. Best Full, GPU OFF, in my half sized preview window which is a waste. Best Half/Auto is fine. I normally edit Preview Auto/Half.
    Do you get different performance with GPU turned off?
  • Philippe Gaudens
    April 8, 2014 at 7:17 am
    Thank you for you answer John, but I just got the Titan Black 2 weeks ago, and I had GTX 590 (dual GPU) before and it was the same problem…
    Here are the details for the footage coming from CANON 5D Mark III:
    General
    Complete name : I:\BJ2C1814.MOV
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 2.71 GiB
    Duration : 4mn 56s
    Overall bit rate mode : Variable
    Overall bit rate : 78.4 Mbps
    Encoded date : UTC 2013-01-12 22:28:49
    Tagged date : UTC 2013-01-13 23:27:17
    ©TSC : 30000
    ©TSZ : 1001
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L5.1
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Format settings, GOP : N=1
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 4mn 56s
    Bit rate mode : Variable
    Bit rate : 76.9 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 1.237
    Stream size : 2.66 GiB (98%)
    Language : English
    Tagged date : UTC 2013-01-12 22:28:49
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Duration : 4mn 56s
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Channel positions : Front: L R
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 54.3 MiB (2%)
    Language : English
    Other
    Type : Time code
    Format : QuickTime TC
    Duration : 4mn 56s
    Time code of first frame : 09:12:10;08
    Time code settings : Striped
    Language : English
    Bit rate mode : CBR
  • Graham Bernard
    April 8, 2014 at 8:16 am
    Well, now, we’re needing to look at the Quick Time Codec.
    What Version are you running?
    Can you PLAY the file in a QT Player?
    Grazie
  • John Rofrano
    April 8, 2014 at 1:04 pm
    [Philippe Gaudens] “I had GTX 590 (dual GPU) before and it was the same problem…”
    Vegas Pro doesn’t support dual GPU either.
    Can you post a small sample video file in this format to the COW? I’d be happy to test playback with my ATI Radeon HD 5870 and see how it performs. Maybe it’s just a difficult file format to decode?
    ~jr
