Activity Forums VEGAS Pro [Kid’s school project] Videos from different cameras… audio pitch problems
  • [Kid’s school project] Videos from different cameras… audio pitch problems
    Posted by Larry Greenman on April 29, 2015 at 12:05 am
    Greetings!
    First post, very grateful to have found this forum… my question: I’m helping put together a video for my kids’ school (using Vegas Pro 12) which involves compiling a lot of little video clips filmed by different parents. Imagine a folder full of video clips, each filmed on different brands of cell phones, cameras, etc., all imported into one Vegas project.
    Problem is – the audio on some clips doesn’t playback at the correct speed. I believe this is because some of the files are 44.1 kHz (clips from a Canon S95, for example), and others are 48kHz. If I set the project preferences to 44.1kHz, the 48kHz clips’ audio pitch plays back too high. If I set the project to 48kHz, the 44.1kHz clips sound too low in pitch.
    How can I fix this? It’s driving me buggy :). Thanks!
    Larry
    Mark Barton replied 11 years, 4 months ago 3 Members · 3 Replies
  • Mark Van der berg
    April 29, 2015 at 7:42 am
    Hey Larry,
    Does going to the Audio Event FX for the files that are the wrong and use ‘Pitch Shift’ not yield results? It might be a bit cumbersome but once you have figured out the right setting it’s a matter of copy-paste of course!
    Hope this helps.
    Mark.
  • Larry Greenman
    April 29, 2015 at 3:35 pm
    Thanks for the quick reply Mark… I will try it! If it works, it works.
    (Although I can’t help feeling like that’s the “wrong” way to do it – like there must be some way to import 48kHz files into a 44.1 project that retains the proper audio pitch…)
  • Mark Barton
    April 29, 2015 at 9:50 pm
    I never noticed an issue. Under Project Properties under the Audio tab, you can set the resample quality to something better to see if that makes a difference. The other option is to resample the audio portion in another program like Sound Forge (Sony)or Audacity (free).
