Activity › Forums › Apple Final Cut Pro Legacy › Kicking Titles in FCP5
  • Kicking Titles in FCP5
    Posted by Paul Jones on August 22, 2005 at 2:46 pm
    I’m getting a strange issue with my titles since upgrading to FCP5
    When I dissolve titles up they kick into a slightly different position at the end of the transition.
    To try and overcome this I don’t use a dissolve, instead I use the opacity slider to fade the titles up, on the frame where the titles have fully appeared I still get a slight kick.
    I am using the FCP built in title generator and have never had this problem before.
    Any help appreciated
    Paul Jones replied 21 years, 1 month ago 3 Members · 4 Replies
  • David Roth weiss
    August 22, 2005 at 3:35 pm
    Sounds like you have an unecessary keyframe at the very end of the motion trk for your problem titles. Delete it and that should fix your problem.
  • Tom Wolsky
    August 22, 2005 at 7:05 pm
    Are you looking at this in real-time, or rendering out on a video monitor?
  • Paul Jones
    August 24, 2005 at 10:22 am
    I have no keyframes at the end of the motion track and I am viewing.
    It is the same real time on the mac monitor and external monitor, everything is rendered !
  • Paul Jones
    August 24, 2005 at 10:28 am
    I’ve just taken advise and lowered my video playback setting from dynamic to high and its cured it.
