Activity › Forums › AJA Video Systems › Ki Pro Mini SDI=>HDMI question
  • Jeremy Garchow
    October 18, 2010 at 2:37 pm
    I dont know for sure as I haven’t seen one yet, but if history serves the outputs are active all the time as with all AJA products. On the mini, though, you won’t be able to up or cross convert. It will basically pass through whatever signal you send it.
    Jeremy
  • Marc Colemont
    October 18, 2010 at 2:55 pm
    That would be fine, no conversion needed in my case.
    I have a smallHD monitor which has many inputs like HDMI, but no HD-SDI.
    Currently I use a HD-SDi to HDMI convertor, but it drains my batteries.
  • Jeremy Garchow
    October 18, 2010 at 3:00 pm
    You should be all good with the mini doing the spigot conversion.
    Jeremy
