Activity › Forums › AJA Video Systems › Ki pro for playback video event
Posted by Patrick Deslauriers on March 14, 2011 at 6:24 pmI WOULD LIKE TO KNOW IF THE KI PRO IS THE BETTER SOLUTION FOR PLAYING VIDEO IN CORPORATE EVENT . WE HAVE MAYBE 20 VIDEOS TO PLAY AND I WOULD LIKE TO KNOW IF IS INSTANT PLAY AND WHAT IS THE WORKFLOW FOR THE CUE ! thanx
Pat Mcgillen replied 14 years, 7 months ago 6 Members · 8 Replies -
Aja Sales department
March 15, 2011 at 8:09 pmPatrick,
Ki Pros are often used for video signage. The Ki Pro can be configured to play one clip or all of the clips on the Storage Module. Additionally, a loop playback feature is also available so that one clip or all of the clips can be looped. Playback from the device can be achieved using the front panel buttons or via web UI control. For detailed information, the Ki Pro operation manual is available from the AJA website:
https://www.aja.com/pdf/support/AJA_KiPro_manual_v2.0.pdfYou can learn more information about the Ki Pro product by visiting our website, calling AJA or one of our resellers.
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com -
Patrick Deslauriers
March 15, 2011 at 9:54 pmI receive this mail from Brian A. Rutz
Thank you for your interest in the products of AJA Video. Your email to our Technical Support Group has been forwarded to Sales Support.
The Ki Pro and Ki Pro Mini are designed as acquisition devices, not as playback units. They record to the Apple Pro Res codec the live output of a camera or camcorder thus maximizing the quality of the recorded video.
In theory you could use an RS422 controller or the web UI to locate a specific clip and play it back though again, this is not the application for which the device was designed.
I suggest you contact one of our ACQUIRE Resellers in Montreal to arrange a demonstration of the Ki Pro. They may be found under the Where to Buy section of our website at https://www.aja.com. -
March 15, 2011 at 10:21 pmPatrick,
I think Brian was simply trying to emphasize that the product was designed for acquisition first and foremost. As he suggestions, it can be used for playback, but since that wasn’t what it was primarily designed for, you might consider visiting your local AJA reseller for a demo to see if it fits your particular needs.—
AJA Video Systems
(800) 251-4224 US
sales@aja.com -
Jeremy Garchow
March 16, 2011 at 2:53 am[Patrick Deslauriers] “I WOULD LIKE TO KNOW IF THE KI PRO IS THE BETTER SOLUTION FOR PLAYING VIDEO IN CORPORATE EVENT”
I guess I would ask better than what?
Absolutely the KiPro can pay files back.
Brian Walker
March 16, 2011 at 5:36 ami only use ki pros for acquisition on shows.. I use PlayBack Pro for playback.
https://dtvideolabs.com/PlaybackPro%20Plus.html
Thanks in advance!
Brian Walker -
Jeremy Garchow
March 16, 2011 at 6:24 pmThought this might be of interest to some of you:
https://www.youtube.com/watch?v=HZZwcOWXNTA
Jeremy
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Marc Colemont
March 27, 2011 at 8:00 amI used it also for playback on an event.
I did number 001-033 in front of the files. But what turns out… The order stayed the same as apparently the file date is been used as file order. Which is a bummer for this application finding all the files. -
Pat Mcgillen
January 23, 2012 at 3:44 amI often use my Ki-Pro’s for playout! One show in particular I play 4 decks simultaneous, 4 screens in sync. Another use is for stingers or fast access for awards shows. I create a show reel in FCP, putting all clips usually in order, then recall each clip via timecode using a JL Cooper es-slomo-j controller, which I can control up to 4 decks with, and random access up to 1000 cue points by cue #. Works well with scripted show with pre-produced content, and full random access.
