Activity › Forums › AJA Video Systems › Ki Pro Corrupt File
  • Ki Pro Corrupt File
    Posted by Ryan Mcafee on July 8, 2013 at 7:25 pm
    This is now a second time we have had this issue.
    We have the Ki Pro Mounted as the primary record deck in a mobile production trailer.
    When we bring the footage back from the trailer the footage is corrupted. The file time length is correct but the file gets stuck in a 3 second loop within a few minutes of the show. So we have 4 hours of a 3 second repeat. Has anyone had this issue?
    Ryan McAfee
    Moon Community Access Television
    http://www.MCA-TV.com
    Kenyon Blower replied 13 years ago 6 Members · 11 Replies
  • 11 Replies
  • Gary Adcock
    July 8, 2013 at 7:31 pm
    [Ryan McAfee] “When we bring the footage back from the trailer the footage is corrupted. The file time length is correct but the file gets stuck in a 3 second loop within a few minutes of the show. So we have 4 hours of a 3 second repeat. Has anyone had this issue?”
    Chances are the file was not finalized completely after you ended the recording, if so there is little you can do, short of sending the file to a recovery service.
    When recording takes in excess of 2 hours, it takes a few minutes to close the file out, on a 4 hour record, it would have taken 15min or so to close the file correctly.
    What software are you using for the edit, note that FCP 7 cannot create a timeline that long.
    Which software version are you using and what was the record format.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    Follow my blog at https://www.garyadcock.com
    Or follow me on Twitter
    @garyadcock
  • Ryan Mcafee
    July 8, 2013 at 8:28 pm
    The file had plenty of time to close. I edit on an Avid Media Composer 6.0. And we were recording on the DNX 145 option on the drive.
    Also I forgot to mention the file has all the audio from the 4 hours but the video does the 3 second looping problem.
    My boss and I think it is a bad deck or possibly power fluctuation problem. Our trailer config has been the same for a year now and we never ran into this problem before.
    Ryan McAfee
  • Gary Adcock
    July 8, 2013 at 9:24 pm
    [Ryan McAfee] “The file had plenty of time to close. I edit on an Avid Media Composer 6.0. And we were recording on the DNX 145 option on the drive.”
    What does Aja support say? sounds like an issue with the DNX encode.
    gary adcock
    Studio37
    Chicago, IL
    @garyadcock
  • Chuck Pullen
    July 9, 2013 at 3:08 pm
    Hi Ryan. I typically experience about a 10 – 20% failure rate with corrupt files on the Ki-Pro. The good news is, that most of the time the file will still play on the Ki-Pro. Just hook it up to a machine with an SDI capture card, and you can recover the file that way.
    Chuck
  • Ryan Mcafee
    July 9, 2013 at 5:43 pm
    [Chuck Pullen] ” Just hook it up to a machine with an SDI capture card, and you can recover the file that way.”
    The file plays back from the ki pro with the same problem.
    Ryan McAfee
  • Ryan Mcafee
    July 9, 2013 at 5:44 pm
    I will let you know, Gary.
    Ryan McAfee
  • Chuck Pullen
    July 9, 2013 at 6:44 pm
    Hmmm… Sorry sounds like you have a bigger issue then. Maybe the drive wasn’t seated or something along those lines? Gary would be the one to figure this one out.
    Chuck
  • Matthew Causon
    July 18, 2013 at 1:21 pm
    Hello Chuck
    Have you been in touch with AJA technical support regarding the corruptions you are experiencing?
    Provided files are closed down correctly using the slot button and there’s no problem with the Ki Stor/s I don’t think you should be seeing these corruptions.
    Best regards
  • Ryan Mcafee
    July 18, 2013 at 2:00 pm
    AJA believed that the Hard Drive went bad. We are being sent a new one and we are return the bad one. Thanks for everyone’s advice.
    Ryan McAfee
  • Kevin Christopher
    August 20, 2013 at 5:10 pm
    I am a little late to the party, but I have had this happen before. The problem is just as Gary sated. the file did not close correctly. It’s a real pain to fix, but most of the time it is recoverable. Try https://aeroquartet.com they have a tool that can tell you if you can recover the file. Then get out your credit card.
    Kevin
