Activity › Forums › Apple Final Cut Pro › Keyword Collections
  • Keyword Collections
    Posted by James Ewart on May 12, 2015 at 7:31 am
    Two odd things and not sure if it’ me.
    Occasionally I want to remove a keyword from a clip. I hit delete and it takes the other keywords as well even though only one is elected and command Z will not undo.
    The other is that clip remains in the keyword collection even after I have deleted the associated keyword.
    Am I being silly I wonder?
    James Ewart replied 11 years, 4 months ago 2 Members · 2 Replies
  • Doug Metz
    May 12, 2015 at 4:28 pm
    Select the clip you want to remove the keyword from, and open the Keyword HUD (cmd+K) – delete the keyword from there, and your clip will disappear from that collection while retaining your other keywords.
    Doug Metz
    Anode
  • James Ewart
    May 13, 2015 at 5:43 am
    Thanks yes I’ve got that.
    If I select the shot in the main event no problem but if I select the shot within a keyword collection it deletes everything but of course it is removing itself from the keyword collection. Should have figured that. I was thinking it was deleting all the keywords but in the main event they are still there.
    Thanks.
    Every now and then I still get a bout of confusedness.
