Activity › Forums › Apple Final Cut Pro Legacy › Keynote to QT Video
  • Keynote to QT Video
    Posted by Mike Brumbaugh on November 13, 2009 at 8:26 pm
    Anyone experienced exporting a Keynote presentation (with short video clips and transitions included)to QuickTime and having the video clips start then stop during play when veiwing the .mov file?
    When I view the exported mov, the video starts but stops a few seconds in. I can see the slider (video controls)is still moving, indicating the presentation is still running. The next slide comes up (as timed)but the video clip never ran the full duration.
    Mike Brumbaugh replied 16 years, 10 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    November 14, 2009 at 1:54 am
    What codec and frame size are you using to export the Keynote presentation?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Zane Barker
    November 14, 2009 at 2:38 am
    [Mike Brumbaugh] “When I view the exported mov, the video starts but stops a few seconds in.”
    That will happen if you don’t give timing to the slides in Keynote. You probably have the slides set to advance when spacebar is pressed in keynote. In Keynote you need to specify the length of time you want the slide to show and then have the transitions to the next slide play after that amount of time.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Mike Brumbaugh
    November 16, 2009 at 2:26 pm
    I used H.264 and I also used ProRes 422.
    Frame sixe is 720×480
  • Mike Brumbaugh
    November 16, 2009 at 2:28 pm
    All slide have timing and are not set to advance via spacebar.
