Activity › Forums › Apple Final Cut Pro › Keying outside of an object in FCPX
  • Keying outside of an object in FCPX
    Posted by Jim Kehoe on November 15, 2014 at 2:35 am
    Hey guys!
    I am having a lot of trouble getting a key right in FCPX, the iphone that this barbie doll is holding has a few green app icons on it and the keyer is keying those out, i DON’T want them keyed out, i want the phone to remain as it is. Any tips on this? Essentially I would like to key everything outside of the main edges of the barbie doll. Also any tips to get rid of the shadows under her dress? Thanks guys! Here is a screenshot of it in FCPX, as you can see there are holes in the phone, i am using FCPX’s default keyer
    John Rofrano replied 11 years, 10 months ago 3 Members · 9 Replies
  • 9 Replies
  • Noah Kadner
    November 15, 2014 at 8:52 am
    Post a still of the image before applying the key filter.
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Jim Kehoe
    November 15, 2014 at 9:30 pm
    Here it is, a screenshot
  • John Rofrano
    November 16, 2014 at 12:23 pm
    If the shot is static, you can use a mask on a duplicate clip above to just mask the phone face like I did here:
    You also need to work on your key because you lost a lot of her hair. It would also be easier if you used a single color green (you have two green backgrounds and the one below the doll is not very solid in color).
    The image above was done just with the Keyer and Mask in FCP X.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jim Kehoe
    November 17, 2014 at 2:37 am
    Hey John thanks for the reply, i cleaned up the key a bit, how would i go about retaining more of her hair?
  • Jim Kehoe
    November 17, 2014 at 3:08 am
    Hey John, also how did you manage to get rid of most of the green spill on her heels? And yes i agree on the working with one solid green screen cloth, but i was working with what i had.
  • Jim Kehoe
    November 17, 2014 at 11:27 am
    Sorry last question John, could you go over what you did to get rid of the spill around the heels and her body using the keyer ans mask? thanks my man!
  • John Rofrano
    November 17, 2014 at 5:08 pm
    [Jim Kehoe] “could you go over what you did to get rid of the spill around the heels and her body using the keyer ans mask?”
    I dropped the Keyer onto the clip. Then I selected Refine Key | Sample Color and drew a rectangle on the preview window under the doll’s legs. That cleaned things up with the lower green screen by her legs.
    For the mask you need to add the same image above as a connected clip and then use the Mask effect and adjusted the corners to match the edges of the phone face. That will cause the face of the phone from the connected clip be displayed instead of the one from the keyed clip.
    ~jr
  • Jim Kehoe
    November 17, 2014 at 10:15 pm
    Wow, after 2 days of trying to get this right your simple advice WORKED! Thanks a lot John!!!
  • John Rofrano
    November 18, 2014 at 2:19 am
    I’m glad that worked for you. Sometimes less… is more. 😉
    ~jr
