Activity Forums Adobe After Effects Keying out white… Trickier than usual
  • Keying out white… Trickier than usual
    Posted by Dylan Hargreaves on June 24, 2015 at 6:10 pm
    Hi folks,
    Trying to key out the white background of some stock footage of a goldfish, so it’s swimming on black. I’ve tried a few methods and none are working well enough – luma key, luma matting, extract, Colorama output phase, (as per a sky replacement.)
    The problem is, the goldfish fins are very whispy and its underside is pretty bright, so it’s either posterizing nastily or leaving a big white outline – even with a choker.
    Am I onto a loser here? Is it time to find some alternative stock, or is there one last solution that I’ve missed?
    Thanks in advance!
    D
    Walter Soyka replied 11 years, 3 months ago 2 Members · 3 Replies
  • Walter Soyka
    June 25, 2015 at 12:40 am
    Without seeing the footage, it’s tough to tell, but…
    You know how you can use UnMult [link] to generate alpha from black? You can do it with white, too. You just need to make an UnMult Sandwich: Invert, UnMult, Invert.
    Sometimes it’s nice to top your UnMult sandwich with a little Levels (Alpha channel).
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Dylan Hargreaves
    June 25, 2015 at 9:02 pm
    Thanks Walter – good to know for next time!
    Ended up going for quite a radical technique:
    1. Went to pet store
    2. Purchased goldfish & tank
    3. Shot goldfish against black background
    4. Voila
    And now my kids have a fish!
  • Walter Soyka
    June 27, 2015 at 4:06 pm
    [Dylan Hargreaves] “3. Shot goldfish against black background”
    Well, that’s cheating 🙂
    Walter Soyka
