Activity Forums Adobe After Effects Keying out Green and Blue in the Same Shot
  • Keying out Green and Blue in the Same Shot
    Posted by Eric Goldstein on May 29, 2008 at 11:30 pm
    I’ve got some green screen footage. I used blue tracking marks on the green screen so I could key them out. I’m using two Keylight effects; one for green, one for blue.
    I’m having trouble getting all the blue out. Also, in trying to get all the blue out, it’s forcing me to push the green key harder and I’m losing some edge information.
    Does anyone have any suggestions on how to improve my results?
    Eric
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
    Eric Goldstein replied 18 years, 3 months ago 5 Members · 11 Replies
  • 11 Replies
  • Michael Gossen
    May 30, 2008 at 12:01 am
    How about precomposing after the first key?
    Michael Gossen
    Helium Digital Media
  • Eric Goldstein
    May 30, 2008 at 12:22 am
    Hi Michael,
    Thanks, precomping the first key solved the problem.
    Eric
    Eric Goldstein
    Los Angeles
  • Eric Goldstein
    May 30, 2008 at 12:46 am
    Hey Michael and anyone else. Let me ammend my response. Precomping the first key helped, but didn’t entirely eliminate the problem. The Greenscreen and the blue tracking marks are well lit. But, even precomping the green key, the later blue key forces the edges of the main key to become rough in order to totally eliminate the blue tracking marks.
    Any other ideas?
    Eric
    Eric Goldstein
    Los Angeles
  • Joey Foreman
    May 30, 2008 at 12:48 am
    No blue in your subject, right? Give this a shot. Key the greenscreen, but lose the keylight for blue. Now duplicate the layer. On the top layer copy, delete keylight, and apply a Hue/Saturation effect. Switch this to blue channel. Now apply a Shift Channels effect. Solo this layer and change the comp view to alpha.
    Now on the shift channels effect switch everything to Red. Now on the Hue/Saturation effect boost the blue saturation and decrease the blue lightness until the markers have vanished – turned pure black – in the comp window alpha view.
    Unsolo this layer and turn on the Alpha Track Matte for the layer below. Switch the comp window back to RGB.
    Did it work?
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
  • Eric Goldstein
    May 30, 2008 at 1:22 am
    Hi Joey,
    Perhaps I’m not doing it properly. I followed your directions, but got a very transparent version of my foreground scene.
    Any thoughts?
    Eric
    Eric Goldstein
    Los Angeles
  • Joey Foreman
    May 30, 2008 at 2:10 am
    The idea is to have the blue markers in the top (matte layer) pure black in the Alpha view, and the subject pure white (except for edges.)
    Solo the top layer again – turning off the track matte on the layer below first, then mouse over the comp window (in Alpha Channel View) and watch the info palette. The background area and the markers should read 0 – pure black, and the subject 255 – pure white. If you aren’t getting these values you can add a levels adjustment to the matte layer, and push the outer triangles in until you have pure black and pure white.
    Then unsolo the layer, turn it off, turn the alpha track matte back on for the layer below, and switch back to RGB view in the comp window.
    Joey Foreman
    Editor/Animator
  • David Bogie
    May 30, 2008 at 2:25 pm
    It’s usually easier to just put masks around tracking markers. They can be tracked if absolutely necessary but simple keyframes should be able to do the chore in most situations.
    You can google using tracking markers and find interesting help. It’s a popular technique.
    bogiesan
  • Michael Gossen
    May 30, 2008 at 10:16 pm
    Yeah,
    Realistically, it would probably take you much less time to matte them out. Depending on your footage and the size of the trackers, you might be able to expand your key a little bit to overflow those areas…if they are too big in the frame, or you are lacking resolution, it might start to break down. I am sure it would be nice to key everything and walk away, I don’t know if I have ever had an easy key, just an easier one… Sometimes a little elbow grease goes a long way. Good luck.
    Michael Gossen
  • Patrick Hearn
    June 2, 2008 at 3:23 pm
    What I’d do is duplicate the layer. On one do the green key, on the other the blue. Now alpha matte the green by the blue. Hopefully that should do it.
    You might possibly have some specks left over. Do junk mattes before keying and perhaps blur the blue layer a little after the key.
  • Eric Goldstein
    June 2, 2008 at 5:29 pm
    Thank you all for your thoughts. In the end it’s probably going to be a little of all the solutions mentioned. I’m going to try to avoid masking as much as possible. I’ve been playing around with multiple layers, but so far haven’t gotten a better result than using two keys on the same layer, but I’m still working on it.
    The thing that’s hurting the key is that the blue tracking marks were made using blue tape. Even though it’s very slight, there’s a slight edge and therefore a very slight shadow around the tracking marks. It’s this shadow that causing what would otherwise be an easy key to be problematic.
    Thanks again,
    Eric
    Eric Goldstein
    Los Angeles
