Activity Forums Apple Final Cut Pro Legacy Keying or Matteing to removing Shadow on White Wall
  • Keying or Matteing to removing Shadow on White Wall
    Posted by Rachel Miller on February 23, 2012 at 1:56 am
    Hello,
    There is a huge shadow on the side of the person being interviewed. Can I key out the shadow or matte the entire wall with white?
    Rachel
    Tony Brittan replied 14 years, 6 months ago 3 Members · 4 Replies
  • Michael Gissing
    February 23, 2012 at 2:05 am
    Is the camera static and the person as well? Without seing the shot it is a bit hard to guess but if you have plenty of time and can rotoscope in Motion you might be able to do that. I doubt there is a quick and easy fix.
  • Rachel Miller
    February 23, 2012 at 2:30 am
    Yes the subject and shadow is static. It is a sit down interview.
  • Michael Gissing
    February 23, 2012 at 2:36 am
    People are rarely static. Any slight head movement and shoulder shrug make simple matting difficult. Keying usually creates an obvious edge. Also the wall needs to be simple.
  • Tony Brittan
    February 23, 2012 at 12:02 pm
    If you have access to AE CS 5.5, the rotobrush makes rotoscoping much easier.
