Activity Forums Adobe Premiere Pro Keying… in PPro… Best result out of what’s given…
  • Keying… in PPro… Best result out of what’s given…
    Posted by Perry Cheng on April 12, 2006 at 4:54 pm
    Experts,
    I have been reading about Keying in this forum, I learned in general people prefer doing it in AE or ultra. However, with limited budget, I want to make best use of what PPro 1.5 has. So, what are some steps to get the most out of it? i.e. shot in front of a Green Screen, well lit, Garbage Matte certain areas in a sequence, then Green Key in another??? (Is this even possible?) Or are there other poor man’s Keying method.
    Sincerely,
    Perry
    Perry Cheng replied 20 years, 4 months ago 2 Members · 2 Replies
  • Dex Craig
    April 12, 2006 at 9:46 pm
    You can key in Premiere Pro — I don’t have PP2, I’m still on PP1.5, but what follows applies to any and all keys.
    Most important aspect to keying is lighting. Be sure you evenly light your greenscreen — no shadows, no soft fades from bright to slightly dimmer. Even a half-stop difference between light and dark areas of the greenscreen can make pulling a key much more difficult. Also, make sure that your greenscreen is at a similar illumination level to the foreground subject (try to keep the difference less than a stop). Do your best to keep green spill from your subject, since you don’t have the same spill supressors you’d have in AE. Use backlight on your subject, as well, to help pop the subject away from the greenscreen. If you can, even put a slightly red (maybe just a CTO) gel on the back and edge lights to help counteract the green spill.
    Do use green for your greenscreen. DV (if that’s what you’re shooting) handles the green information in the frame with more detail, so you’ll get better keys off green.
    If your greenscreen is well lit you can get a decent result with the Chroma Key effect. Select the color from the greenscreen, obviously enough. I find a similarity of about 15 or so works pretty well, with smoothing set to “high.” The Color Key effect is about as good, as well, and you can use the Edge Thin and Edge Feather to minimize artifacts around the edge of your subject, but it’s easy to gobble up details from the edges with thinning, so be careful.
    Sometimes the Remove Matte effect is useful, too, but it can also create a jaggy edge to the key.
    It’s not going to be the best key in the world, but depending on what you’re doing with it, it can be adequate.
    Hope that’s helpful.
    – Dex
  • Perry Cheng
    April 13, 2006 at 1:13 am
    Thanks Dex. I appreciate your insight. How do you do a “Edge Thin” or “Edge Feather” in PPro, by the way?
    Perry
