Activity › Forums › Adobe Premiere Pro › Keying in numerical values to change duration/move clips
  • Keying in numerical values to change duration/move clips
    Posted by Bryant Stanton on May 29, 2014 at 6:50 pm
    Hello!
    Hopefully the title wasn’t too vague. I’ve recently started the transition to Premiere from FCP7 and I’ve been very happy so far.
    My question is about a move I used quite often in FCP. If I were to highlight a clip and just type +12 then ENTER in the timeline, the clip would move forward 12 frames. Same would happen if I used the trim tool to extend a clip, etc.
    I know I can still use option arrows to move clips and add handles/change lengths, but is there a way to key in numerical values like I was able to in the past? It’s not a deal breaker for me, but it was something that was often handy for speeding up my workflow, so I’m hoping it’s possible.
    Thanks in advance for any help!
    Phil Lebeau replied 12 years, 3 months ago 3 Members · 3 Replies
  • Phil Lebeau
    May 30, 2014 at 6:03 am
    I think you are talking about the NUDGE tool? Premier CC – Edit – Keyboard Short cuts – search for nudge.
    See if that is what you are looking to do.
    Phil LeBeau
  • Ivan Myles
    May 30, 2014 at 10:51 am
    [Bryant Stanton] “If I were to highlight a clip and just type +12 then ENTER in the timeline, the clip would move forward 12 frames.”
    Should work in Premiere: highlight the clip(s), type “+” or “-“, and enter the desired increment in frames or timecode.
  • Ivan Myles
    May 30, 2014 at 11:01 am
    Slide a clip one frame at a time using:
    {ALT} + {LEFT ARROW}
    {ALT] + {RIGHT ARROW}
    Use {ALT} + {SHIFT} + {L/R ARROW} to move five frames at a time.
    Reference: Default keyboard shortcuts in CS6
