Activity › Forums › Adobe After Effects › Keying GIF image background
  • Michael Szalapski
    February 4, 2016 at 9:45 pm
    Use the Extract effect rather than Keylight.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • John Cuevas
    February 5, 2016 at 2:18 pm
    You might also try a luma key and set it to key out brighter.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    February 5, 2016 at 2:48 pm
    The big issue is you are working with a very compressed image, so removing all the white that occurs due to the motion blur is going to be practically impossible.
    ThinkCK
  • Tom Gilbert
    March 1, 2016 at 12:19 pm
    Thank you guys for helping me out.
    Like John said, it was impossible to correct edges automatically, so I had to do it manually via photoshop. Interesting that in photoshop I had 24 different layers, while AE showed 42 frames, where some of them were duplicated. However, the best that worked for me about auto fixing edges in AE was to add “shift channels” and “find edges” effects. Then I created adjustment layer below and changed it to luma inverted. Then added various color changing effects to it.
