Activity Forums Cinematography Keying: Canon 5DmkII v. Canon XH A1
  • Keying: Canon 5DmkII v. Canon XH A1
    Posted by Jay Carr on July 15, 2011 at 6:09 pm
    So, I have access to both of these cameras at work but, for reason I won’t go into, I can’t just sit down and run a full set of tests to figure out which of the two is actually better for green screen keying. So I wanted to know, from you experts here, which of the two cameras is better for green screen work.
    As a quick reminder, the XH A1 shots in HDV 1080p30 with a compression rate of 4:2:0 (if I am reading this thing right). Where as the 5D captures .mov .h264 1080p, also with a compression rate of 4:2:0 (I got that info from Philip Bloom, so I believe it ;-).)
    Any thoughts? I know they have the same compression ratio, but I’m told that DV and HDV’s compressors kinda suck. So… yeah, thoughts?
    Thanks a billion.
    Jay Carr replied 15 years, 1 month ago 2 Members · 2 Replies
  • Grinner Hester
    July 16, 2011 at 3:53 pm
    HDV is 5:1 in a 4:1:1 color world. The 5DmII shoots far superior pictures so it’s quite the no brainer.
  • Jay Carr
    July 16, 2011 at 5:38 pm
    Ah, clearly I wasn’t “reading this thing correctly”. Yeah, now that I have the right data, it’s a no brainer. Thanks!
