Activity › Forums › Adobe After Effects › Keyframing the beginning and end of a mask?
  • Keyframing the beginning and end of a mask?
    Posted by Gabi Bucataru on May 22, 2015 at 2:55 pm
    Hi Gang!
    So I need a mask on this layer only for a few frames somewhere in the middle but not anything before and after that region.
    What’s a good way to do this? I see that the none/add/substract dropdown option is not keyframable.
    thanks!
    gabi
    Daniel Waldron replied 11 years, 4 months ago 3 Members · 2 Replies
  • John Cuevas
    May 22, 2015 at 4:37 pm
    You could create a keyframe 1 frame before and one frame after your mask, where it is the size of screen.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Daniel Waldron
    May 22, 2015 at 9:00 pm
    You could also split the layer immediately before and after where you want the mask so your masked layer is its own very short layer. Command+Shift+D (or its PC equivalent) will split it at the spot of the playhead.
