Activity › Forums › Adobe After Effects › Keyframing Effects
  • Keyframing Effects
    Posted by Charles Williams on August 20, 2011 at 7:45 am
    is it possible to keyframe toggle effects on and off. so i have some green screen footage with 5 different effects on it. Keylight, (3)Curves effects, Denoise and degrain. and what i want is for the footage to play, pause and then each effect toggle on one by one to show before and after. can this be done by somehow getting the individual effects on and off switches to toggle on by keyframe?
    Charles J Williams
    David Johnson replied 15 years, 1 month ago 2 Members · 1 Reply
  • David Johnson
    August 20, 2011 at 2:06 pm
    You don’t even need keyframes … just put the effects on Adjustment Layers instead of directly on the footage layer, then set the in points of each Adjustment Layer accordingly.
