Activity › Forums › Maxon Cinema 4D › keyframes to after effcets
  • keyframes to after effcets
    Posted by Gon Perdigao on February 25, 2009 at 11:18 am
    Hi there,
    i want to render a scene that the objects go with the key frames to after effects.
    i think that might be with multipass, but what multipass should i use, if is not with multipass, how should i do it? Thanks
    Gon Perdigao replied 17 years, 7 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    February 25, 2009 at 2:20 pm
    You can’t export actual geometry to AE. For keyframed data you can export cameras, lights, and position/rotation values for any other object that you’ve supplied with a 3D data tag (assuming you’ve checked 3d data export in render properties).
    Otherwise you can export an overall alpha channel, alphas for individual objects (with object buffers), and various other passes (shadows, reflections, depth, etc.).
  • Gon Perdigao
    February 25, 2009 at 2:55 pm
    to export the 3D data is in the compositing project file? Or i need a tag?
    can you explain how i can do it?
    Thanks for your reply
  • Adam Trachtenberg
    February 25, 2009 at 5:32 pm
    Sorry, it’s actually called the “external compositing” tag in the English version. Then in the render settings>compositing export section you need to check the “include 3D data” box.
  • Gon Perdigao
    February 25, 2009 at 5:55 pm
    thanks a lot, you really help me :)!!!!!!!!!!
