Activity Forums Apple Final Cut Pro Legacy keyframes short cut?
  • keyframes short cut?
    Posted by Accountclosed on November 9, 2006 at 3:54 pm
    when inserting keyframes, in say a filter, is there a quick way of turning all the keyframes on rather than clicking on the radio buttons or using the opt pen tool to insert them?
    frequent keyframe changes means a lot of clicking. any one know a short cut to insert them all?
    Kevin Monahan replied 19 years, 10 months ago 4 Members · 4 Replies
  • Pablito
    November 9, 2006 at 4:27 pm
    Yes, there is… I am not sure if it is alt-k or something similar… check out the short cut table in the fcp user manual…
  • Bret Williams
    November 9, 2006 at 4:29 pm
    One you’ve created one keyframe, any adjustment made will create a new keyframe or adjust the current one. No need to click the keyframe button again unless you’re making a keyframe with no changes.
  • Accountclosed
    November 9, 2006 at 5:31 pm
    sorry, did not make myself very clear. the short cut to add motion frames is ctrl k. this only works in the motion tab. what i want to do is be able to add key frames in the controls tab for generators and filters tab for filters. for example with g film there are 24 atttributes. if i want to change some or all of these these every 25 frames over 20 secs is there a short cut to insert keyfames for every attribute in the same way there is for motion keyframes?
  • Kevin Monahan
    November 10, 2006 at 6:10 pm
