Keyframes on slider in main comp not affecting pre comps as expected.
Hi.
Have set up a slider in a main comp to control some position animations in a precomp. It works until I add keyframes, then nothing. I think I need to add a valueAtTime expression to offset the start time of the precomp (which starts in the main comp at 11.19 seconds). Thing is I don’t know which parameter or comp I would need to add the ValueAtTime expression.
The set up is a simple slider control in the main comp to control the x position of a few layers in the pre comp. the layers I want to control are all connected to the slider and work until the keyframes are set. If I move the precomp to the very start of the Main comp, all works perfectly, even with keyframes. Where do I put the expression and what is the expression syntax I would need to add?
Thanks in advance.
